send rx & tx data in single wire
38505512
Dec 3, 2014
8
Dec 3, 2014
8
hello my friends
i have an qstion
i was wonder if someone can help me.
i want send and receive rx & tx in same wire and i don't have any good idea .
can someone help me?
thanks for you'r attention.
Harald Kapp
13,720
13,720
At the same time or one after the other?
If you want to transmit and receive at the same time, you wil need a modulation scheme which uses e.g. different carrier frequencies to separate transmit and receive direction.
If you want to transmit and receive one after another, you can use a technique called half-duplex (example here)
38505512
Dec 3, 2014
8
Dec 3, 2014
8
thank you Harald Kapp
i need half duplex communicate .
i will check your suggestion web and try them.
Doug3004
Sep 5, 2014
119
Sep 5, 2014
119
There is also the Dallas 1-Wire protocol:
https://en.wikipedia.org/wiki/1-Wire
It allows 2-way communication but its main limitation is that in any group of connected devices, it requires that one device be designated as the master and all others as slaves.
There are Arduino libraries for it around online.
Or you can just write your own software version of it.
