I'm relatively new to using Electric Ducted Fans, and I was wondering if anybody could suggest an ESC that would be suitable for controlling this EDF, after being connected to a Raspberry Pi, to avoid me selecting anything that would be unsuitable.
The EDF
Working Voltage: 3s -4s
Motor : Brushless Motor 2839 2600kv
Maximum Current: 35-49A
Thrust: 1.1-1.4kg
The Battery
Battery Type:LiPo Battery
Volts:14.8v
Capacity:1500mAh
Cell Count:4S
Cell Configuration:4S1P
Continuous Discharge:40C
Max Burst Rate:70C
Max Volts per Cell:4.2V
Max Volts per Pack:16.8V
Charge Rate:1C (5A)
Max Approved Charge Rate:5C (25A)
Wire Gauge:14 AWG Soft and Flexible Low Resistance Silicone Wire
Plug Type:XT60
Thank you in advance for the help.
The EDF
Thrust: 1.1-1.4kg
The Battery
Volts:14.8v
Capacity:1500mAh
Cell Count:4S
Max Burst Rate:70C
Charge Rate:1C (5A)
Plug Type:XT60
