Segate 2TB HD
Discussion in 'Datasheets, Manuals and Component Identification' started by William G Whitaker, Dec 27, 2016.
  1. William G Whitaker
    William G Whitaker
    Dec 27, 2016
    14
    HI
    I have a Segate 2TB hd model ST2000dm001External HD. My old info Seagate labels it as GoFlex I removed the plastic housing to see if the rating was written on the bare unit. All i found were the words Seagate Barracuda with 2 ratings 5 vdc .75A and beneath 12 vdc .43 A. I am not using it and haven’t for several months. i wanted to give it to one in my family. i searched for all the info i had including the wall wort. i could not find a power supply with the same size plug. So I went to the Seagate site and found that this style of HD as driven by either 5 or 12 volts. I found that i do have a larger wort that has three connectors on it. I did not measure its output before I found out what one of them fits with Segate’s original power supply. I have ample test power supplies but I still want someone to tell me if they have this 2TB HD what is the VDC out put of their wort. Maybe it can use either ?? Does anyone know. If you have one like this what is the DCV.
    billwhit1@comcast.net
    #1
    1. Advertisements
  2. William G Whitaker
    23,510
    2,176
    Most often the power supplies for these supply BOTH 5V and 12V.
    (*steve*), Dec 28, 2016
    #2
    davenn likes this.
    1. Advertisements
  3. William G Whitaker
    bushtech
    Sep 13, 2016
    553
    38
    Vaalkopdam North West
    I have a 1Tb goflex. Dc output of wall wart 12V 2A.
    bushtech, Dec 28, 2016
    #3
    1. Advertisements
Similar Threads
Loading...
