seeking some advice/knowledge relating to RF communication
Cona
Oct 2, 2014
3
Oct 2, 2014
3
Hello!
I would like to ask a question regarding the abilities of RF communication.
I am looking at making a little project/device that would be capable of sending a distress signal over a RF.
The objective is to create a small device that has the ability to send a small piece of information (such as gps coordinates) to a recipient. The environment in which this device would be situated in is my major hurdle; which would be a state forest/land reserve.
Would it be possible to to send the mentioned information over a relatively dense environment for 5-10km?
or is it simply impossible given the following requirements..(I am not very experienced in RF technology)
- The device would need to be small (handheld).
- The device would need to be battery operated.
- The device would also need to power a gps.
Would something like this achieve this, they state that it has a 7-10km range, but the environmental factors would adversely affect this.
SO if anyone has any other products that would match this form factor and exceed in range, please let me know.
http://www.csgshop.com/product.php?id_product=86
Regards,
Connor
davenn
14,268
14,268
hi Connor
welcome to Electronics Point :)
that device would be 7 - 70 km under near line of sight condition and possible with a directional antenna ( a yagi)
you would be limited to a low gain whip antenna and foliage absorption would be reasonably high ( very high if it was wet with rain etc)
you may only get a couple of km at best
You would also have to check with your local authorities ( I don't know what country you are in ??)
to make sure that you can legally use it at that power level without a licence
cheers
Cona
Oct 2, 2014
3
Oct 2, 2014
3
hi Connor
cheers
Thanks for the response and information, yes liaising with the relevant authorities is a must. But I must be able to produce a sound design to present. I am in Brisbane, Australia. Is anyone aware of any such transmitter that is compact, power efficient and has a strong broadcast? or additionally any information regarding how the range could be extended without sacrificing the scale of the device?
Regards,
Connor
davenn
14,268
14,268
Yeah ... agreed and that was going to be my possible response at some stage
Connor, do you realise there are already commercially available emergency locator beacons ?
They transmit on 2 freq's ---- 121.5 and 243 MHz. There are a number of satellites that monitor these freq's
and can triangulate a beacon's location to around 10 - 20 metres pretty much anywhere on the planet
there's a zillion wwww sites about and selling them
I remember many yrs ago back in NZ during the 1990's there was a great calamity down the road from home that the local rubbish site. Police, ambulance and fire service all converging on the dumpsite.
Later found out some clown had disposed of a ELB and hadn't removed the battery before dumping it
it switched itself on and caused a huge fuss
cheers
davenn
14,268
14,268
I notice there have been freq changes since I was working with them back in the 1990's
406.025 MHz digital transmission seems to be the main one now
the 121.5 and 243 MHz were analog transmitters
Cona
Oct 2, 2014
3
Oct 2, 2014
3
They transmit on 2 freq's ---- 121 and 243 MHz. There are a number of satellites that monitor these freq's
cheers
Yes I do, its actually on the 406MHz freq. This is my other option, In laymen terms I am striving for the most power efficient, accurate device with the smallest form factor; this device will not just be a safety device, it will also be used to track and record much more information; which will be utilised by sports people. (e.g heart rate monitor, gps progress tracker) the ELB system is secondary. I am merely investigating different methods of sending an SOS, and my research has shown that emitting an SOS on the 406 feq will most likely be my best bet.
davenn
14,268
14,268
OK well that's a whole different ballgame. you are really going to struggle to get any significant distance
in difficult terrain from a small portable system
yes and for that you will have to use a commercial ELB transmitter ... you are not going to replicate one
7,682
7,682
Maybe this is a stupid question, but is there reliable cellular service in the area?
Gryd3
Jun 25, 2014
4,098
Jun 25, 2014
4,098
Would need to be a high powered transmitter, or some strategic placed sensitive receivers.
Would need to be on a freq that is clear and available to use without upsetting anyone on the wrong RF spectrum.
Would need to transmit sparsely to conserve battery power...
This does not sound like a project that can be built by a beginner, or even many moderate electronics enthusiasts. You need to be able to understand how different RF frequencies travel and propagate, as well as determining what output power is required for the given distances / environments you wish to use the product in.
Buying a pre-made product sounds like the way to go, or modifying/adding to an existing product that may have the characteristics you require.
BobK brings up a good point regarding cellular service. A simple SMS could relay the information you require.
Existing products like this will be hard to compete against > http://www.findmespot.ca/en/
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
perhaps some drones with repeaters?
