G
G.T. W.
Hello
I'm trying to figure what I am doing wrong when comparing the
input/output of a schmitt trigger in an energized circuit.
This is a MC7414 chip on a pcb, in a centerfuge operating under its own
power supply. The circuit board is on a floating ground, I measured
5.1 Volts (RMS) between pins 14 and 7 with a Fluke meter.
Unfortuneately, the only o'scope available to compare input/output was
a digital unit, first one I've seen. Everything was set to 'auto',
there was no manual on how to confirm its settings.
I set the first probe to the 7414, pin 1(input). A positive pulse was
seen there. A second probe was put on the output (pin 2) to observe
the re-shaped output. There was no wave-shaping, no squared pulse.
Both traces appeared identical, a positive-going pulse, rounded at the
half-power points. Further, the output was not inverted.
Due to my ignorance with a digital o'scope, I can not say what the true
pulse amplitude was. Using pin 7 as a ground reference for the probe,
the digital readout indicated pin 1 was 174 volts (I looked
very hard for a decimal point, there wasn't one).
My questions is.
What condition could cause a schmitt trigger to pass a signal
unchanged, instead of re-shaping it? If the input pulse was, for
example, 1.74 volts, and the schmitt trigger won't go high until 1.8
volts, does it pass the signal unchanged? I had the same result with
each gate on this chip. Thank you.
My questions is.
