schematic and wiring diagram for Magnavox MWR10D6
Discussion in 'Datasheets, Manuals and Component Identification' started by tedstruk, Jan 10, 2017.
  1. tedstruk
    tedstruk
    Jan 7, 2012
    447
    7
    Toledo Washington
    This is a DVD recorder. Sept 2006. Appears to have power, but the power light doesn't light, and it is dead to the user. There are over 73 AC volts from the main power fuse to AV output grounds.
    #1
    1. Advertisements
  2. tedstruk
    Gryd3
    Jun 25, 2014
    4,094
    873
    Fraser Valley. Canada, BC
    Please continue to talk about the issue on the original topic.
    Creating duplicates can create confusion, and splitting a topic into smaller related pieces makes it harder for others with the same/similar problem to follow along.
    Certainly sounds like the original post is here : https://www.electronicspoint.com/th...ds-av-output-jack-ground.282112/#post-1719250
    Gryd3, Jan 10, 2017
    #2
    Ian likes this.
    1. Advertisements
