Categories
Platforms
Content
Proceed on . . . . you certainly don't see 1100 watts on your Samsung back of set specifications sticker . . . .do you ?
but if the relay needs to switch 3 - 4A at 12 - 30 V then a 3A relay will be under rated
Sires . . . . . . . .
After seeing that original relay . . . .shudder . . .shudder . . . . is there full assurance that you will not delaminate a PCB foil connection on the replacement of the relay? And will do quality soldering on the board / joints ?
RELAY LEAD MODIFICATIONS :
73s de Edd
Sir rutwad. . . . . . . .
Why . . .'soitanly . . . .
It’s just that I am edu-guessing that Samsung might have initially had their power supply design prototype
and then jobbed it out to be manufactured by 2 or 3 other firms / closet subsidiaries.
OR they might have just loosely given out their requirement specs and let others build them.
They were multi sourcing it . . . . . so as not to be caught in problem situations.
At any rate I am NOT currently finding any spot-on EXACT schematics of your unit.
Question:
Are there being any visible signs or responses from unit as per a LED lighting, or even a blip or any sound response of that little musical tone sequence / ditty that Samsung’s make, when it is now being turned on ?
Or with its additional two note solo, when it is being turned off.
You say:
I get 120vAC, 120vAC, 5vDC, and ground.
If you are measuring that RL802S's 5 VDC relay coils power, that means that the sets omnipresent 5VDC standby power supply is being O.K..
ALSO . . . . .Confirm that the 5VDC drops off, when the set is turned off.
Your measuring of that 120VAC on BOTH terminals of the relays POWER contacts, confirms that they are closing.
HOWEVER, that is merely being a " phantom " static leakage AC measurement, since you are using a COLD /isolated / floating ground on the relay coil side, while trying to take a measurement over on the HOT ( AC line connected portion of the power supply.)
Lets now additionally see if there actually IS being a DYNAMIC raw DC rectified B+ voltage of about 160-170 VDC present and being switched by the new relays power contacts . . . or . . . if possibly, that voltage IS NOT being present.
This will require the same test as was done before, but this time connect your DC metering negative test lead to a HOT ground.
The easiest, definitive access point, is being at the string of 5 looooong 450 VDC rated electrolytics towards center board from your just installed relay.
Use one of the negative marked leads of the electrolytic caps.
Testee-testee time . . . . .
73s de Edd
Question:
You say:
73s de Edd
Ok, so what now?
Anything? This is my only TV.
I would like to mention that prior to my $4000 Samsung,
