S
Stephen Boulet
I've designed a 6-pole Sallen-key op amp filter (so three stages) as a
reconstruction filter after a DAC. It's a low pass filter with a corner
near 90 kHz.
At the input to the filter, SNR is about 67 dB, and it goes down to 65.4
dB after stage 1, 60.1 dB after stage 2, and 55.4 dB after stage 3.
The last two stages have higher Q than the first stage.
Basically, the noise floor keeps creeping up across the stages (I'm
using a TL3474A op amp). It seems to me that the op amp noise isn't the
culprit, because at 40 nV/sqrt(Hz) it's over 100 dB below the signal.
Are there some general things I should be looking out that some of you
with more analog audio design experience can share? Thanks.
Stephen
near 90 kHz.
Stephen
