RSSI measurement
Status
Not open for further replies.
enrakeshkumar
Feb 15, 2016
3
Feb 15, 2016
3
I have 2 tranceivers and i have to measure the rssi value at any one of those tranceivers.
Please help me by providing any circuit to measure the Rssi value..or any other method to measure rssi value of the signal.
Thanks in advance.
davenn
14,262
14,262
Thanks in advance.
we cant do that until you supply a circuit of the receivers used in your system
Many receiver chips have an RSSI output pin from which signal strength can be measured and or displayed on a meter
Harald Kapp
13,725
13,725
RSSI has no fixed unit, it is an arbitrary value assigned to the relative strength of the received signal. If your receiver doesn't provide a built-in indication of received signal strength (which it may well have), it will not be easy to create such an indication by external means. You will have to tune a separate receiver to the same frequency your transceivers use and measure the received signal strength.
enrakeshkumar
Feb 15, 2016
3
Feb 15, 2016
3
Actually one of my tranceiver is fixed and another is moving.
Moving tranceiver has to send signal to fixed tranceiver then it has to transmit that signal again to the moving tranceiver.
I need rssi value to deal with the distance between those tranceivers
Help me out with any other ideas..
Thank u.
davenn
14,262
14,262
and that just makes the RSSI variable
that cant be done with the info you have so far supplied as it is subject to so many variables
and RSSI isn't going to tell you what you want anyway
for the TX --- transmitter power, frequency, coax losses ( if any) antenna gain
in between TX and RX ... obstructions etc
for the RX --- receive antenna gain, coax losses ( if any), receiver front end gain, noise figure etc
Status
