S
sno
Article and interview 21 July 2011:
Check it out:
http://pesn.com/2011/07/21/9501874_Rossis_Self_Sustaining_One_Megawatt_Reactor
I have been following this for about a year, appears to be a very simple
device, table top size.
Stainless steel pipe packed with granulated nickle (initially claimed
nickle needed to be mixed with proprietary catalyst, claims has
determined optimum nickle granular size)
Water jacket surrounding pipe, with insulation.
Hydrogen pumped through nickle packed pipe.
Two pumps, one for hydrogen one for water.
Water converted to steam (is a steam generator)
Initial energy input needed to heat nickle/hydrogen and trigger reaction.
Reaction is self sustaining after initial trigger.
Had problem with thermal run away causing explosions, which he thinks
have been solved (steam/hydrogen explosion....??)
Has a hypothesis of how it works using conventional physics, basically
fusion of nickle/hydrogen producing copper. (copper has been found in
nickle after running)
Claims has had a generator running for over a year.
Gamma radiation detected while running, no radiation detected after 20
minutes being turned off.
Has been examined by reputable physicists and no external energy inputs
discovered, except for initial trigger energy/pumps (three hundred watt
constant input, kw's in thermal energy, constant output).
Another company has claimed they have built their own (different....???)
device using nickle/hydrogen, seems to verify rossi's claims.
have fun.....sno
Correct Scientific Terminology:
Hypothesis - a guess as to why or how something occurs
Theory - a hypothesis that has been checked by enough experiments
to be generally assumed to be true.
Law - a hypothesis that has been checked by enough experiments
in enough different ways that it is assumed to be truer then a theory.
Note: nothing is proven in science, things are assumed to be true.
Check it out:
have fun.....sno
