JC
Any scanner experts? I picked up a Ricoh IS420 (similar to IS430, manual
is available online) for cheap, (yeah right), so it does all its
initializing things then gives the 2 flashing lights on the front which
indicates a bad lamp. This is a big large format scanner so worth fixing
in my opinion as parts are available. So, the lamp is green (?), and is
bright enough to hurt my eyes so I guess its ok? When the scanner
initializes it moves the lamp assy an inch or so back and forth then
raises the paper feeder and beeps and fails. Now I got it cheap enough
to buy a new lamp, BUT is there some other stuff I should check? The
mirrors are very clean and I guess installed correctly, this printer is
very user friendly from a lamp/mirror replacement point. Any ideas? Do
the ccd's fail? TIA
the ccd's fail? TIA
