RGB Led cube and more..
ASiiMO
Nov 12, 2016
3
Nov 12, 2016
3
Hello people,
I am Julian, and I am 14 years old.
And I am new to this forum so im gonna make alot of mistakes I'm sorry.
I am from the Netherlands and we don't have alot of electronic shops etc.
I am also new to electronic circuits and stuff.
I am wanting to build a led cube, especially a rgb led cube, but I don't want to spend a lot of money, I'd like to spend around 10-25€ if that is possible, I want to use a arduino zero? If that's something, it's the very small version of the arduino, knockoff or not, doesn't matter.
I want to program it and it has to be rgb like 0-255 red, 0-255 green and 0-255 blue, so I can make alot of colors, rainbow s and animations. (And especially a lot of fun, and show it to my friends)
What size should I go for ? 5x5x5, 125 leds? I really don't know, help is very apriciated. (Sorry for my English)
And I don't know how i start this 'project' I am beginner, I do have alot of computer knowledge and programming but none of microcontrollers etc.
Thanks for your time
-Julian
Colin Mitchell
Aug 31, 2014
1,416
Aug 31, 2014
1,416
Start with a 3D LED Light Squared DIY Kit 8x8x8 3mm LED Cube White LED Blue/Green/Red/Yellow for $16.00, delivered to your front door. The LEDs do not change colour but they produce all sorts of different patterns and effects. You can select: blue, green red or yellow LEDs when you buy the kit.
Or you can buy your own LEDs and mix them.
ASiiMO
Nov 12, 2016
3
Nov 12, 2016
3
Thanks!
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
I'd also recommend you read this:
http://www.instructables.com/id/Led-Cube-8x8x8/step1/Software-Effect-launcher/
Understand the complexity of a 1 bit 8x8x8 cube, and then contemplate that you are asking for a 24bit 8x8x8 cube.
Not only will the wiring be 3 times as complex (for the three colors) but you need to transfer 24 times the amount of information for each frame (1.5k vs 64 bytes)
NMNeil
Oct 3, 2014
111
Oct 3, 2014
111
I highly recommend the Youtube channel of Great Scott. I learn a great deal from him.
