RF filter tuning
Status
Not open for further replies.
EricWatson
May 15, 2015
May 15, 2015
How do you tune an RF filter circuit. what is the test setup like and what are the basic procedures
How do you Tune RF circuit that are Lumped Element filters, filter bands, waveguide filters, Millimeter Wave Filters in the Low Pass, Band Pass, Band Stop, High Pass that are in the ranges from low MHz to the High GHz frequency ranges?
How do you measure Filters Parameters like S-Parameters, Phase Linearity, Filters Ripple, Pulse Ringing?
davenn
14,260
14,260
hi
welcome :)
normally you would use a sweep oscillator ( that covers the freq range of the filter) that is sync'ed to a spectrum analyser or network analyser
with that setup you would see where the filter is resonating and you would be able to adjust it accordingly
poor mystic
Apr 8, 2011
1,074
Apr 8, 2011
1,074
:) or try this...
Line-up without test gear
There are limited options for doing the same job with no test equipment, but people succeed nevertheless.
Usually a carrier wave is modulated with a tone and the set under test is tuned so that the tone can be heard. The RF stages are adjusted to maximise the clarity of the tone. The process needs to be carried out twice, once with the carrier tuned to the bottom of the passband, and again at the top of the passband.
RONEN NADAV - ZARKOR
May 19, 2017
May 19, 2017
Hi, You can modulate the filter with a filter program and simulate measuring filters parameters like S-Parameters, Phase Linearity, Filters Ripple, Pulse Ringing and get filters response to any input signal.
for eample google Superfilter program for RF and Digital filters combinations at:
superfilter.net
davenn
14,260
14,260
hi @RONEN NADAV - ZARKOR
this thread is 3 years old and the OP never returned to comment on the original responses
Please try and avoid reviving threads that are 6 months or older
thanks lots
thread closed
Status
