Reversing polarity on push of a button
Status
Not open for further replies.
LightShow
Jun 9, 2016
111
Jun 9, 2016
111
Hey guys..
im helping a mate repair and restore his 1990 mx5 miata of which he has a motor controlled exhaust valve that opens and closes by swapping polarity, this used to be controlled by a box and a reciever however this box broke and now no longer is available to be used.. at the moment i have the exhaust connected to a dpdt momentary switch however he wants to integrate a single momentary push button to control the opening and closing of the valve..
basically the need is - a single momentary push button to reverse the polarity of the motor however the circuit must be capable of 15A at 12V and must also not output anything when the button is not pressed
So basically push button (outputs 12v and GND) release button (No Positive output) Push button (outputs GND and 12v (Reverse Polarity))
Also Circuit will be installed in a car so it should be capable of up to 14.4V
Anyone got any ideas??
Regards, lightshow
AnalogKid
Jun 10, 2015
2,896
Jun 10, 2015
2,896
This can be done with a latching DPDT relay (also called an impulse relay) and a SPST momentary switch. The problem is finding parts rated for 20 A DC.
ak
LightShow
Jun 9, 2016
111
Jun 9, 2016
111
ak
how would that circuit be wired? constant power into the relay as well as the switch then the output off the relay? and are they able to NOT output voltage when no buttons are pressed?
LightShow
Jun 9, 2016
111
Jun 9, 2016
111
ak
and honestly i think it could be run on 10A DC
AnalogKid
Jun 10, 2015
2,896
Jun 10, 2015
2,896
For long term reliability, contacts should be rated for twice the load they carry.
ak
Externet
Aug 24, 2009
891
Aug 24, 2009
891
The hard part for a momentary DPDT is "must also not output anything when the button is not pressed"
Doing it with a momentary push switch in series to a DPDT switch is easy.
And a momentary up/down window switch type has center off, also applicable but has two buttons, if you can live with it.
----> https://www.ebay.com/itm/POLARIS-RZ...ash=item3ae6de3207:g:CGcAAOSwXY5ZPxim&vxp=mtr
Look at wreckyards and for other models/years that such control was implemented by Mazda.
Try calling
----> http://www.car-part.com/
----> http://treasurecoastmiata.com/c-370437-used-miata-parts-miata-90-97-electrical-engine-and-body.html
----> http://www.planet-miata.com/index.php?section=31630995
The whole ----> https://www.ebay.com/itm/60mm-Wirel...693787?hash=item3f79d1369b:g:gXwAAOSwAfpatKwD
Alec_t
Jul 7, 2015
3,591
Jul 7, 2015
3,591
There is also the little matter of should the valve automatically return to the default state (presumably closed) when the ignition is turned off?
AnalogKid
Jun 10, 2015
2,896
Jun 10, 2015
2,896
Something about my initial reading led me to think he wants the latest state to be latched even when power is off, so the car starts up in the previous state.
LightShow - ?
ak
hevans1944
Hop - AC8NS
Jun 21, 2012
4,887
Jun 21, 2012
4,887
A mechanically latching DPDT relay with outputs (12 VDC and Ground) in series with DPST N.O. contacts on the push-button switch could work. Problem is, this type of relay generally has two coils which must be energized alternately to change the relay state. How to do this with a single N.O. contact on a push-button switch is problematic. Energy storage capacitors and steering diodes come to mind, but the last time I developed such a circuit was in the 1960s where it was used for a mechanically raster-scanned optics table. The customer needed to preserve the scan direction to allow the scan to resume in the same direction after a power failure. Needless to say, this was waaay before personal computer ICs became available.
It should be very easy to implement this with a small PIC microprocessor today. Choose one with non-volatile, program-accessable flash memory to preserve valve state after a power interruption. The PIC can drive either real relays with its output, or use power MOSFET switches.
LightShow
Jun 9, 2016
111
Jun 9, 2016
111
Try calling
currently as it stands we have it on a momentary on/off/on switch in the dash however the "want" is for a single push button
It would be nice for it to close when the ignition is off however its not absolutely needed
LightShow - ?
ak
Again its sorta eh it doesnt matter too much
This seems really cool! but unfortunately i have no idea about programming IC's the most ive done is made basic arduino scripts and sent them through an FTDI
LightShow
Jun 9, 2016
111
Jun 9, 2016
111
wants to use this - https://www.adafruit.com/product/558 (or something like it)
this is what he already has - https://www.avsontheweb.com/momentary-on-off-on-rocker-switch-6-prong/
the wiring at the moment is like this
-Dedicated 12v Constant power Run from battery (alot of the wiring is shot in the car so i ran new everything)
-Dedicated wiring going to the exhaust valve
-both wires are coming through to the dash where they are wired to the switch in this configuration
(except its not a window motor and its not a ford xD)
-system is fused behind the switch with a 15A inline and at the boot with a 50A main fuse for all the new power runs
The exhaust system is this
60227-my-3-custom-exhaust-spring-loaded-flapper-valve-62355d1239235277-xforce-varex-muffler-remote-control-varex2pp9.png
Alec_t
Jul 7, 2015
3,591
Jul 7, 2015
3,591
If it really must be single-button operated and you don't want to go the micro-controller route, here's the basis for a circuit to do the job :-
The relays are the common automotive type with contacts rated to handle the DC motor current. Depending on the relay coil current draw, N-channel MOSFETS M1-3 could be replaced by BJTs.
U1a is half of a dual-latch IC and toggles state each time the button is pressed. Its unused inputs should be grounded. M2 enables either relay to be energised, but only when the button is held down.
The simulation file is attached if anyone wants to play.
  • ExhaustValveController2.asc
LightShow
Jun 9, 2016
111
Jun 9, 2016
111
WOW you went above and beyond! Many many many thanks! What software did you use??
AnalogKid
Jun 10, 2015
2,896
Jun 10, 2015
2,896
This thread died out over three years ago. The right way to do this is to start your own thread with your own question and details. You can link to this thread for context/history if needed.
ak
Status
