Show us a circuit.
There is a schematic of the board in the thread, above, I drew it, you have to open it to see it....
Show us a circuit.
Sorry, you're a bit late with your endeavour. Have a look e.g. here.
Man you are an arduino fan aren't you!What do you expect a "wiring diagram" to show that a schematic does not?
You contradict yourself with the image in post #25. I'd call that a schematic diagram, too. I get the impression that your 'wiring diagram' is what we'd call a schematic, just on another level, showing boards and/or devices and their interconnections instead of electronic components.A wiring diagram is a completely different set of documents than a schematic.
You're free to annotate any kind of schemtaic diagram. This is used for example to note jumper settings, assembly options etc.that noted any special info on the board
So does Harald know the difference between a wiring diagram and a schematic?"any advice I give"
Back in the day, when ISA ruled and headphones were a special mindset, there were these things on all the boards called "PINS".
Huh? Never used an Arduino.Man you are an arduino fan aren't you!
If I don't know what kind of push button switch was installed here, what kind of switch should I use? I am attempting to wire a subminiture switch inplace of the original, but I don't know how the original switch operated, if it was simply a ground on/off,- or a power side by side 3x3- or a grounded 2 way, 4 on or 4 off.
