Rest problem 89C2051
Discussion in '8bit Microcontrollers' started by ClueLess, Feb 23, 2008.
  1. ClueLess
    ClueLess Guest
    Hi all
    I am just toying with 89C2051 and I have assembled a program to switch
    on a series of LEDs using the rl a instruction. The program works well
    on the simulator. But I cannot make it work on the breadboard.
    The problem is with the reset. I am using an available 32.768kHz
    crystal, I have used the standard 33pf caps too.
    On the reset pin I have tried 1 uf, 10uf capacitors and also
    resistances of various values to the ground from the reset pin. Still
    no go.
    Can someone in the know among you help me with some leads?
    Thanks for your time and attention
    ClueLess
    #1
    1. Advertisements
  2. ClueLess
    Eeyore Guest
    ClueLess wrote:
    > Hi all
    > no go.
    Why do you think the problem is with the reset ?
    It's only 2 components. You can hardly go wrong ! How have you connected
    it ?
    Graham
    Eeyore, Feb 23, 2008
    #2
    1. Advertisements
  3. ClueLess
    Eeyore Guest
    I'd check that the watch crystal is designed to be used with 33pF caps.
    The first one I looked at is designed for use with 12pF caps.
    Graham
    #3
  4. ClueLess
    ClueLess Guest
    On Sat, 23 Feb 2008 16:07:40 +0000, Eeyore
    Since I did not have a 12pf cap handy I tried with a 4 mHz crystal
    with 33pf caps. Still no go. As I said the code works very well in the
    simulator.
    Any more suggestions?
    Thanks for taking time to help me
    ClueLess
    ClueLess, Feb 24, 2008
    #4
  5. ClueLess
    ClueLess Guest
    simulator.
    ClueLess
    PS: Did not see this after several hours. So posting again :-(
    ClueLess, Feb 25, 2008
    #5
  6. ClueLess
    ClueLess Guest
    Well, it started working when I caught hold of the crystal with my
    fingers :-(
    True, it seems to want more capacitor. But it is totally not in
    agreement with what I have read.
    How this can be?
    ClueLess
    ClueLess, Feb 26, 2008
    #6
  7. ClueLess
    Eeyore Guest
    > fingers :-(
    You mean it's OK now ? Good to hear.
    I expected it to want less capacitance actually !
    > But it is totally not in agreement with what I have read.
    > How this can be?
    Do you have the manufacturer's data for that specific crystal you are using
    ? If not, you need to get it.
    Beware of things like stray capacitance from PCB traces and also it may be a
    good idea to ground the cystal's metal can.
    Graham
    Eeyore, Feb 26, 2008
    #7
  8. ClueLess
    ClueLess Guest
    On Tue, 26 Feb 2008 19:15:14 +0000, Eeyore
    The data sheet says 12.5 pf which I do not have at the moment,
    unfortunately. I will have to order it.
    Meantime I modified the program to work with a 4 mHz crystal and 33 pf
    caps and it worked first shot.
    So it is only the crystal interfacing - the key is in the caps, I
    think.
    I will post the results once I get hold of the 12.5 pf stuff.
    Thanks for your continued interest in helping me
    ClueLess
    ClueLess, Feb 28, 2008
    #8
  9. ClueLess
    ClueLess Guest
    On Sat, 23 Feb 2008 20:37:32 +0530, ClueLess
    Hi Graham
    I got a clue from someone in the 8052.com to insert a 300k resistor
    between the crystal and the xtal2 pin. And it worked.
    Problem solved. And again thanks for your interest.
    ClueLess
    #9
    1. Advertisements
