Resistor ID on stove igniter board 9758080
Stormsorter
May 6, 2014
10
May 6, 2014
10
I'm trying to find what the unmarked green resistor at R1 should be. R2 on the left side is 51ohm but that obviously doesn't mean R1 is.
I'm iffy about trying to repair the burnt trace with wire but the friend that it belongs to insists that I try. I would also like to confirm that the 2μ7 k on orange capacitor means 2.7μf as it also needs replaced. He believes that a mouse urinated on the board and caused the short that took it out.
I'm no technician of any kind, but apparently since I can solder and play around with LED's my friend thinks I can fix it. Soldering is easy, finding whats needs replaced is easier said then done, especially when you have no training of any kind.
davenn
14,260
14,260
Hi there
welcome to the forums :)
have you actually tried to measure it with a multi-meter in the resistance range ?
lift one end and try, altho the resistor has got hot, it may not have failed
cheers
Stormsorter
May 6, 2014
10
May 6, 2014
10
Pretty sure it's toast, no continuity. I'll unsolder one leg and test again when I get my new multimeter in a day or two. Hopefully every function works properly on this one, I had to send the first one back. It wouldn't read DC voltage and capacitance never zeroed out but seemed to read ok. My $5 Menards special that it was suppose to replace stopped reading ohms in the 100's and can't read capacitance.
Now that I think about it I'm probably sol unless someone that has a stove with the same board reads this thread and is kind enough to take it out and test.
Stormsorter
May 6, 2014
10
May 6, 2014
10
Incase anyone is interested I found a list of model number for all stoves that use this board. The list is so long I will use the spoiler tag help keep the thread uncluttered. The board I'm dealing with is 9758080 Rev. A.
I did find a refurb for $65 so he might go for that.
But until then check your stove, then check the list to help me, help a friend.
FGS325RQ0
FGS325RQ1
FGS325RQ2
FGS326RD0
FGS326RD1
FGS326RD2
FGS326RD3
GFG461LVB0
GFG461LVB1
GFG461LVB2
GFG461LVQ0
GFG461LVQ1
GFG461LVQ2
GFG461LVS0
GFG461LVS1
GFG461LVS2
GFG461LVT0
GFG461LVT1
GFG461LVT2
GFG464LVB0
GFG464LVB1
GFG464LVB2
GFG464LVQ0
GFG464LVQ1
GFG464LVS0
GFG464LVS1
GFG464LVS2
GFG471LVB0
GFG471LVB1
GFG471LVB2
GFG471LVQ0
GFG471LVQ1
GFG471LVQ2
GFG471LVS0
GFG471LVS1
GFG471LVS2
GS395LEHS0
GS440LEMB3
GS440LEMB4
GS440LEMB5
GS440LEMQ3
GS440LEMQ4
GS440LEMQ5
GS440LEMT3
GS440LEMT4
GS440LEMT5
GS445LEMS2
GS445LEMS3
GS445LEMS4
GS445LEMS5
GS470LEMB1
GS470LEMB2
GS470LEMB3
GS470LEMB4
GS470LEMQ1
GS470LEMQ2
GS470LEMQ3
GS470LEMQ4
GS470LEMT1
GS470LEMT2
GS470LEMT3
GS475LEMS2
GS475LEMS3
GS475LEMS4
GS563LXSB0
GS563LXSB1
GS563LXSQ0
GS563LXSQ1
GS563LXSS0
GS563LXSS1
GS563LXST0
GS563LXST1
GS773LXSB0
GS773LXSQ0
GS773LXSS0
GW395LEPB00
GW395LEPB01
GW395LEPB02
GW395LEPB03
GW395LEPB04
GW395LEPQ00
GW395LEPQ01
GW395LEPQ02
GW395LEPQ03
GW395LEPQ04
GW395LEPS00
GW395LEPS01
GW395LEPS02
GW395LEPS03
GW395LEPS04
GW395LEPT00
GW395LEPT01
GW395LEPT02
GW395LEPT03
GW395LEPT04
IGS325RQ0
IGS325RQ1
IGS325RQ2
IGS326RD0
IGS326RD1
IGS326RD2
IGS365RS0
IGS365RS1
IGS365RS2
IGS385RS0
IGS385RS1
IGS385RS2
IGS385RS3
KGRA806PBL00
KGRA806PBL01
KGRA806PBL02
KGRA806PBT00
KGRA806PBT01
KGRA806PBT02
KGRA806PSS00
KGRA806PSS01
KGRA806PSS02
KGRA806PWH00
KGRA806PWH01
KGRA806PWH02
KGRI801PBL00
KGRI801PBL01
KGRI801PBS00
KGRI801PBS01
KGRI801PWH00
KGRI801PWH01
KGRK806PBL00
KGRK806PBL01
KGRK806PBL02
KGRK806PBT00
KGRK806PBT01
KGRK806PBT02
KGRK806PSS00
KGRK806PSS01
KGRK806PSS02
KGRK806PWH00
KGRK806PWH01
KGRK806PWH02
KGRS807SBL00
KGRS807SBL01
KGRS807SBL02
KGRS807SBT00
KGRS807SBT01
KGRS807SSS00
KGRS807SSS01
KGRS807SSS02
KGRS807SSS03
KGRS807SWH00
KGRS807SWH01
KGRS807SWH02
KGRS807XSP00
KGRS807XSP01
KGSA906PBL00
KGSA906PBL01
KGSA906PBL02
KGSA906PBT00
KGSA906PBT01
KGSA906PBT02
KGSA906PSS00
KGSA906PSS01
KGSA906PSS02
KGSA906PWH00
KGSA906PWH01
KGSA906PWH02
KGSI901PBL00
KGSI901PBL01
KGSI901PBL02
KGSI901PBS00
KGSI901PBS01
KGSI901PBS02
KGSI901PSS00
KGSI901PWH00
KGSI901PWH01
KGSI901PWH02
KGSK901SBL00
KGSK901SBL01
KGSK901SBL02
KGSK901SSS00
KGSK901SSS01
KGSK901SSS02
KGSK901SSS03
KGSK901SWH00
KGSK901SWH01
KGSK901SWH02
KGSS907SBL00
KGSS907SBL01
KGSS907SBL02
KGSS907SBL03
KGSS907SBT00
KGSS907SBT01
KGSS907SSS00
KGSS907SSS01
KGSS907SSS02
KGSS907SSS03
KGSS907SWH00
KGSS907SWH01
KGSS907SWH02
KGSS907SWH03
KGSS907XSP00
KGSS907XSP01
SF196LEMB1
SF196LEMQ1
SF196LEMT0
SF196LEMT1
SF196LEPB0
SF196LEPB1
SF196LEPB2
SF196LEPB3
SF196LEPQ0
SF196LEPQ1
SF196LEPQ2
SF196LEPQ3
SF196LEPT0
SF196LEPT1
SF196LEPT2
SF196LEPT3
SF262LXSB0
SF262LXSB1
SF262LXSQ0
SF262LXSQ1
SF262LXST0
SF262LXST1
SF262LXSW0
SF262LXSW1
SF265LXTB0
SF265LXTB1
SF265LXTB2
SF265LXTQ0
SF265LXTQ1
SF265LXTQ2
SF265LXTS0
SF265LXTS1
SF265LXTS2
SF265LXTT0
SF265LXTT1
SF265LXTT2
SF272LXTD0
SF272LXTD1
SF272LXTD2
SF362LXSB0
SF362LXSB1
SF362LXSQ0
SF362LXSQ1
SF362LXSS0
SF362LXSS1
SF362LXST0
SF362LXST1
SF362LXSY0
SF362LXSY1
SF362LXTB0
SF362LXTB1
SF362LXTQ0
SF362LXTQ1
SF362LXTS0
SF362LXTS1
SF362LXTT0
SF362LXTT1
SF362LXTY0
SF362LXTY1
SF367LEMB1
SF367LEMQ1
SF367LEMT1
SF367LEMW1
SF367LSXQ0
SF367LSXQ1
SF367LXSB0
SF367LXSB1
SF367LXSQ0
SF367LXSQ1
SF367LXSS0
SF367LXSS1
SF367LXSY0
SF367LXSY1
SF368LEPB0
SF368LEPB1
SF368LEPB2
SF368LEPB3
SF368LEPQ0
SF368LEPQ1
SF368LEPQ2
SF368LEPQ3
SF368LEPS0
SF368LEPS1
SF368LEPS2
SF368LEPS3
SF368LEPT0
SF368LEPT1
SF368LEPT2
SF368LEPT3
SF368LEPW
SF368LEPW0
SF368LEPW1
SF368LEPW2
SF368LEPW3
SF369LEMQ1
SF369LEMT1
SF369LEPB1
SF369LEPQ0
SF369LEPQ1
SF369LEPQ2
SF369LEPQ3
SF369LEPS1
SF369LEPS2
SF369LEPS3
SF369LEPT0
SF369LEPT1
SF369LEPT2
SF369LEPT3
SF377PEGQ0
SF378LEPB0
SF378LEPB1
SF378LEPB2
SF378LEPB3
SF378LEPQ0
SF378LEPQ1
SF378LEPQ2
SF378LEPQ3
SF378LEPS0
SF378LEPS1
SF378LEPS2
SF378LEPS3
SF378LEPT0
SF378LEPT1
SF378LEPT2
SF379LEMS1
SF380LEMQ1
SF380LEMT1
SF380LEPB0
SF380LEPB2
SF380LEPB3
SF380LEPQ0
SF380LEPQ2
SF380LEPQ3
SF380LEPS0
SF380LEPS2
SF380LEPS3
SF380LEPT0
SF380LEPT2
SF380LEPT3
SF462LXSB0
SF462LXSB1
SF462LXSQ0
SF462LXSQ1
SF462LXSS0
SF462LXSS1
SF462LXST0
SF462LXST1
TGS325MB5
TGS325MB6
TGS325MQ1
TGS325MQ2
TGS325MQ3
TGS325MQ4
TGS325MQ5
TGS325MQ6
TGS325MT1
TGS325MT2
TGS325MT3
TGS325MT5
TGS325MT6
TGS325VB0
TGS325VB1
TGS325VB2
TGS325VQ0
TGS325VQ1
TGS325VQ2
TGS325VT0
TGS325VT1
TGS325VT2
TGS326MS1
TGS326MS2
TGS326RD0
TGS326RD1
TGS326RD2
TGS326TD0
TGS326TD1
TGS326VD0
TGS326VD1
TGS326VD2
WFG361LVB0
WFG361LVB1
WFG361LVB2
WFG361LVD0
WFG361LVD1
WFG361LVD2
WFG361LVQ0
WFG361LVQ1
WFG361LVQ2
WFG361LVS0
WFG361LVS1
WFG361LVS2
WFG361LVT0
WFG361LVT1
WFG361LVT2
WFG366LVB0
WFG366LVQ0
WFG366LVS0
WFG366LVT0
WFG371LVB0
WFG371LVB1
WFG371LVB2
WFG371LVD0
WFG371LVD1
WFG371LVQ0
WFG371LVQ1
WFG371LVQ2
WFG371LVS0
WFG371LVS1
WFG371LVS2
WFG374LVB0
WFG374LVB1
WFG374LVB2
WFG374LVB3
WFG374LVD0
WFG374LVD1
WFG374LVQ0
WFG374LVQ1
WFG374LVQ2
WFG374LVQ3
WFG374LVS0
WFG374LVS1
WFG374LVS2
WFG374LVS3
WFG381LVB0
WFG381LVB1
WFG381LVB2
WFG381LVQ0
WFG381LVQ1
WFG381LVQ2
WFG381LVS0
WFG381LVS1
WFG381LVS2
shrtrnd
Jan 15, 2010
3,876
Jan 15, 2010
3,876
It seems obvious, but because so many manufacturers use this board, did you try to Google a schematic for this board part number?
If a schematic is out there, you can eliminate a lot of guess-work.
pyromaniac4382
Feb 7, 2013
61
Feb 7, 2013
61
Hello,
In many revisions of this board I see R1 and R2 as identical. I am going to say your best bet is to go with a 51R. Those look like some beefy resistors.
I am sure that this boards is identical. At some point they moved to a different resistor material without the band indication. See picture below. Not sure if you can make out the resistors bands.
http://www.rcappliancepartsimages.com/dbImages/00002863/00861461.jpg
This one seems to be in the same realm, but you can clearly see the resistor value,
Stormsorter
May 6, 2014
10
May 6, 2014
10
I did search for a schematic with no luck.
Thanks for the pictures. As always I overlook the simplest solutions.
Pick one tells me R1 and R2 are the same but the bands look like brown or red, gray, green or black, which is way off going by my 51 and pic two's 47. I'll lift a leg and retest R2 when my new multimeter gets here tomorrow.
After digging around and comparing sizes I would guess its about a 2-2.25 watt. Mine measured about 12mm x 4mm.
pyromaniac4382
Feb 7, 2013
61
Feb 7, 2013
61
Well not quite. It isn't an order of magnitude off if it was brown grey black which is 18 Ohms. Plus the date code on the first picture is 2002 so there were probably many revisions of this board after this as parts became cheaper. I have a feeling with something this massively produced that there was a range of resistance that would satisfy the constraints. The reoccurring theme however between all of the pictures is that R1 and R2 are identical. I would not be surprised if you measure R1 around 51Ohms since you pointed out before R2 has 51R printed on it. The resistors used were probably whatever was cheapest during that revision of the board during that time of the year with some set of constraints to be honest.
Stormsorter
May 6, 2014
10
May 6, 2014
10
Thanks for the info. Both are unmarked, R1 is toast, no continuity. R2 measured 51ohms but that was without lifting a leg, which I would probably never have thought of if davenn hadn't mentioned it in the first reply. The board I'm working on has Rev. A on the sticker.
Stormsorter
May 6, 2014
10
May 6, 2014
10
The replacement meter seems to work ok so far. I removed and retested every component on the burnt trace and only the unmarked resistor is bad. Even the 2.7uf cap tested ok once removed from the board.
Now I'm just sitting here debating on ordering a pair of 47ohm 2w that I found on ebay, using a pair of 33ohm 3w than I pulled from some junk or, digging around more to find or buy the original 51ohm 2w.
I'm also debating on what to repair the burnt trace with. Stranded copper or should I try to find a solid strand close to the volume of the trace?
pyromaniac4382
Feb 7, 2013
61
Feb 7, 2013
61
I would go with whatever R2 Measures at on the resistor setting with a leg lifted since with little information I can only assume that R1 and R2 are identical from looking at a few pictures. To mount the components I would use solid core since once you set it, it won't be moving around, but using stranded shouldn't hurt. If you have any scrap PC's or power supplies that wire would probably suffice, power supply wire is a bit beefy.
Stormsorter
May 6, 2014
10
May 6, 2014
10
Like you I figured better safe then sorry and ordered some 51ohm 2w flameproofs. He's in no rush anyway since it only stops him from using the oven.
