Replacing Christmas light bulbs.
Discussion in 'Troubleshooting and Repair' started by Kat, Dec 6, 2017.
  1. Kat
    Kat
    Dec 6, 2017
    Can I use a 6 volt bulb to replace a 2.5 volt bulb in a string of Christmas lights?
    Kat, Dec 6, 2017
    #1
    1. Advertisements
  2. Kat
    Bluejets
    Oct 5, 2014
    2,240
    446
    Maybe, maybe not.
    Depends what each bulb is.
    At best, you will get maybe 1/6 the light output for the same wattage rating bulb.
    i.e.a 6v 2.5w bulb replacing a 2.5v 2.5w bulb will only give you around 0.4w
    Chances are it will probably not light up at all.
    Bluejets, Dec 7, 2017
    #2
    1. Advertisements
  3. Kat
    duke37
    Jan 9, 2011
    4,771
    591
    Derbyshire. UK
    If the bulbs are in series, then the bulb current is more important than voltage. A low current bulb would go pop since the other bulbs in the string would control the current.
    How many bulbs in the string? To run off your mains you would need about 50 in series.
    duke37, Dec 7, 2017
    #3
  4. Kat
    shrtrnd
    Jan 15, 2010
    3,498
    414
    Arizona
    Any stores near you that might carry the replacement bulb you need? I think most places are going to LED's now, but a small package of replacement bulbs for the old strings used to be pretty cheap.
    shrtrnd, Dec 7, 2017
    #4
    1. Advertisements
