Mishtipaan, the little section of circuit board shown in your picture looks like part of the control panel of a smoke/fire alarm system, with two wires going to a sounder. It's hard to tell from your picture, but it looks like there are terminals to run a wire pair to each of 2 sounders, "2" and "1" reading left to right. Only sounder "1" is connected.
It's hard to tell from your picture where the resistor is/was connected. If the broken resistor was connected to the unused (no wires) terminals for sounder "2", then you're okay: You can just replace it. If I'm right, your system interface (usually a keypad with display) is showing a Sounder Trouble of some sort.
On the other hand, if it was connected to sounder "1", the terminal pair being used, then you should mention it, because it's important. I won't get into why unless that's the case.
I'm only familiar with control panels used in North America, but if you can give me a brand and model number for your control panel, then I can probably look up the resistor you need. There are two values to shop for, the resistance and the Watts rating. That looks like a 1/8 W resistor, and that would be typical for North American panels, but it can be hard to tell from a picture. I just don't know the terminal screw size of that unfamiliar panel.
EDIT: In North America, those control panels usually are inside a steel cabinet with a wiring diagram inside the door, which will usually show the resistors used--they're called "End of Line Resistors" (EOLR), and the values are usually named on the diagram.
