S
Skybuck Flying
Hello,
It might not be possible to purchase the Creative Labs Home Theater/Cinema
Cable...
Somebody wrote me that there is nothing special to this cable.
This cable works as follows he wrote:
There is nothing 'magic' about the 3 to 4 cable to the S750. The S750
has four stereo 3.5mm jack sockets ( three bands on the plug. left, right
and ground). That gives you eight analogue inputs 2+2+2+2 ( or 7.1 as the
sub input is not given the status of a full channel only .1 ). The P.C. end
has only three plugs due to the lack of space on the sound card. To still
give you eight analogue channels two of the plugs are the four band type (
e.g. three channels and ground) that gives you 3+3+2 = 8. Any good quality
'HI-FI' amps will do, but the more you spend the better the sound quality
you will get (usually).
So from this it appears maybe this creative labs home theater cable can be
replaced with standard cables, maybe something like this:
3 cables which split as follows into 8 cables total:
Soundblaster outputs Receiver 7.1 analog inputs
----- 4 channels ------
------ 3 (?) channels ------
What's the name of these cables ?
What kind/type of cables are these ?
Where can I see these cables ?
Where can I purchase these cables ?
Would last cable be a 3 or 4 channel cable ? Maybe it don't matter.
(Loose hanging cable doesn't seem to smart so probably 3 channel cable )
Thanks for any help !
Bye,
Skybuck.
Cable...
Bye,
Skybuck.
