W
Walter Harley
I'm replacing the electrolytics in a nearly-40-year-old HP 654A test
oscillator. This is a 10Hz to 10MHz sinewave oscillator. I have the
service manual and schematics for it.
Many of the caps are specified in the service manual to be tantalum. Some
are quite large values, up to 390uF. The caps are all axial (cylinders with
leads at each end), which is a relatively uncommon package these days.
Can I replace these large-value tantalum caps with aluminum caps? I'm
thinking that in 1967, the ESR, tolerance, and stability of aluminum was
pretty lousy, but maybe now it's as good as tantalum was back then?
Thanks for any input.
