Hello all!
My company's system administrator asked me to fix a water level detector by replacing the sensor which is completely rusted and does not work any more.
The detector has some kind of alarm that triggers when current flows through the sensor. It's basically made by a sensor controlling the base of a transistor, which will be used to amplify signal (with 3 chained transistors) to power the alarm. All of this is powered by a 9V battery.
The problem is that the sensor he gave me to replace the old one is current passing by default, so I had to build a small inverter circuit (with a pair of resistors and an NPN transistor)... and that circuit is consuming current. I used the same resistor the circuit uses, which is about 5.6KOhms, which makes a permanent consumption of nearly 1.6mA (against nearly 0 with the old circuit). According to the usual charge of a 9V battery, this battery would be discharged in about 13 days, which is really a bad thing!
Perhaps I should just replace the defecting sensor with a pair of wires ? Or is there a way for me to reduce the used current ? I don't really know how to compute the maximum resistance I could use for the inverter circuit (I'm not english, and don't know the terms I should use on my favorite search engine)
