REPAIR HELP: Philips Speaker System 2.1 SPA2360/17
anneelise
Aug 30, 2018
Aug 30, 2018
Can someone help me identify these parts? I'm trying to repair an old set of speakers that caught on fire recently (lmao)
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
They are 'pentawatt' package devices and integrated audio amplifiers potentially TDA2003 or TDA2030 etc. As they are all identical (U1,2,3,4 etc) can you see any identification marks on any of them?
dave9
Mar 5, 2017
1,188
Mar 5, 2017
1,188
Map the pinout of that IC, the function of each pin based on the circuit leading to it, and measure the supply voltage getting to it. This will tell you whether you can just drop in something like TDA2030.
davenn
14,260
14,260
And they are just ferrite beads epoxied onto a straight bit of wire to form a choke
readily available
nepow
Jul 18, 2011
99
Jul 18, 2011
99
You could try locating a schematic on line Google he model number.
dave9
Mar 5, 2017
1,188
Mar 5, 2017
1,188
If you get really bored you might see if you can hold a soldering iron on the leg of the ferrite bead, wait for it to degrade the epoxy, then use a couple pair of pliers to pull the lead out so you can stuff a new wire through. Worst comes to worst, you have wasted two minutes and will have to spend more time hunting one down.
This is another example of why I cannibalized a bunch of gear years ago, little things like a ferrite bead (that don't age/decay unless there is a fault) where it's more time to hunt down and more in postage than it's worth.
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
Did you cut the lead to L1? or did it fuse. If the latter, then there is something very wrong elsewhere. You could try replacing it with a plain wire.
