Note that the original question sorta hinted that this is a NEW
Samsung TV. "Great Deal" around Christmas time usually means he
bought it on sale somewhere. Unless someone at the factory smokes, I
doubt if the TV had time to accumulate enough tar and crud to stink.
oven.
Yep. My method is to use common 90% alcohol and give it a bath. If
immersion is possible, I do it. Hitting it with a hot water spray, to
wash off the ionic contaminants, water soluble flux residue, and
general accumulate crud, is not beneath my dignity. The trick is to
immediately blow dry the boards with an air compressor (with a dryer
filter attached). If there's something involved that's porous (wood
or press board cabinetry) or can't be washed (paper speaker cones),
then I have to let it air dry for a few days. Otherwise, the smell is
usually gone with the blow dry.
Yep. To keep my office/shop clean, I won't let anything inside until
the dust has been blown out and all the crud removed. I clean
everything, even if I later decide that it's not worth repairing.
Yep. For the ultimate mess, I have to deal with a machine shop that
uses various plastic case laptops and PC's near the machines. Hot
chips melt and imbed themselves in the plastic parts. Oil, dust, and
dirt adds to the mess. I usually have to scrape the case for chips
with a putty knife before I can safely move it. I wanted to baptize
the PC in the vapor degreaser, but the owner wouldn't let me.
Another fun mess are kids laptops that are literally wallpapered with
stickers, pogs, and stick-on skins. All the sticky back stuff can be
removed with some solvent or other, but there's no solvent that will
reliably remove all the different types of sticky glue.
# Jeff Liebermann 150 Felker St #D Santa Cruz CA 95060
# 831-336-2558
http://802.11junk.com [email protected]
http://www.LearnByDestroying.com AE6KS
