Remote control circuit of old TV?
Wahaj87
Jun 3, 2018
19
Jun 3, 2018
19
Hi, I have this Tv.
National colour tv
matsushita electric industrial co., Ltd. Made in japan
model TC-2620spmr
I require its remote control circuit with PCB diagram. I could not find it in market.
Any help to make its remote will be appreciated.
Tv main board PCB is attached.
dave9
Mar 5, 2017
1,188
Mar 5, 2017
1,188
It seems like a futile effort to make a remote control for a TV that old. They haven't been made in Japan for many years and it's a wonder that it still works. Certainly it has a short life left.
Regardless, I would buy a universal remote control that comes with a lot of codes and try each code listed for anything Matsushita or Panasonic, or perhaps contact some companies that much these remotes and ask if that model TV is supported.
Wahaj87
Jun 3, 2018
19
Jun 3, 2018
19
..... and it's a wonder that it still works. Certainly it has a nnshort life left....
Hi Dave,
I like wonders, like all others. It nice to read your suggestions.
I have tried some universal remotes, but in vain.
Can you suggest a more simple remote control circuit which can move this TV from stand by mode to on mode, in other words a one button remote. For other functions like volume and channels I will do the wonder later.
davenn
14,264
14,264
without knowing the specifics needed, you unfortunately ask the impossible :(
It mite not even be IR remote ??? is it
a lot of TV's back then used ultrasonic remotes
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
If you can find the schematic for the set you can discover the model of remote control IC that was used and, from that, the coding that the chip uses or, potentially, an actual matching 'sending' chip.
Wahaj87
Jun 3, 2018
19
Jun 3, 2018
19
If you can find the schematic ......., an actual matching 'sending' chip.
Hi kellys_eye,
Your suggestion is very good and hopeful. I will try to find the chip on board.
What are the steps to make/find "sending chip"? And how to do it? e.g., coding etc.
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
List the devices (IC's) on the circuit board beside the IR module (IC10, IC11???).
You can get datasheets for 99.9% of all IC's from the likes of http://www.alldatasheet.com/ that will show all the required information.
Wahaj87
Jun 3, 2018
19
Jun 3, 2018
19
Hi kellys,
Is to make a remote control the "sending chip" is same as that on the receiving end on main board of the tv?
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
No, bu the datasheet for the receiving chip will identify the sending chip as they form a 'pair' - indeed the datasheet for the receiver may well show a schematic for a working circuit for the sender side. Other datasheets on the same type of device have done so (as I found some years ago when I was 'into' that kind of thing).
Wahaj87
Jun 3, 2018
19
Jun 3, 2018
19
Hi kellys,
You have given a starting point. May it will take long, a month or two but I will try it. Thanks.
I will update the thread if the wonder comes to eye.
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
Matsushita is 'Panasonic' (I think) and the protocol for their old remote controls is:
http://users.telenet.be/davshomepage/panacode.htm
It doesn't state which device is used to generate this code and it may now be an obsolete device anyway but you can always use an Arduino (or similar) to chuck the signal out to an IR LED and 'play around'.
Worst case would be that the TV had its own processor and they coded the IR into that......
Anyway, whatever route you take, good luck in your search!
If you got hold of the full TV schematic it would be easier to hardwire a newer model remote control receiver into the control lines!
Wahaj87
Jun 3, 2018
19
Jun 3, 2018
19
Matsushita ....
Hi kellys, you mentioned about full TV schematic. Unfortunately I do not have it. I only have layout which I have already uploaded here.
Can you guide from where i can download such old schematics?
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
Can you post a picture of the TV set - and a close-up (readable) image of the rear cover?
I can't find any results using Google which I find to be strange!
Wahaj87
Jun 3, 2018
19
Jun 3, 2018
19
Hi kellys,
Both pictures are attached. The layout picture already uploaded was also captured from tv back hard board.
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
I've got some 'feelers' out to see if I can find something more useful...... will post back here if I find anything.
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
Information so far is that the set uses a Panasonic G11 chassis. I'm still trying to get more details.
Can you post a picture of the board attached to the IR receiver block i.e. the board with IC10 and IC11 on it?
Wahaj87
Jun 3, 2018
19
Jun 3, 2018
19
Info ... that the set uses a Panasonic G11 chassis.
Hi kellys,
For that picture you may have to wait till 16 june, as set is not with me right now. :(
Thanks for your sincere efforts.
Wahaj87
Jun 3, 2018
19
Jun 3, 2018
19
Hi Kelly,
Figure is attached.
There is no IR module found as shown in layout diagram. Instead a IR receiver with number Fps 5138-1T is in its place, who's three wire connector is not connected to any thing. Its picture is also attached. And picture of empty case of IR module is also attached.
Waiting for your expert opinion.
