Relay swap pinout
ThaNerd
Dec 16, 2017
4
Dec 16, 2017
4
I am trying to swap a relay but I can't seem to match the pinout. Both relays have 6 pins but they are not aligned the same way. I am not even sure if I can swap one with the other. I am trying to boost the amp that is why I am swapping them.
Initial relay is: sla-12vdc-sl-c
New relay is: 507h-1ah-f-s
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
The initial relay has CHANGE-OVER contacts but the new one has only NORMALLY-OPEN contacts.
If you need a change-over function then the new relay won't work.
ThaNerd
Dec 16, 2017
4
Dec 16, 2017
4
It was on a LINEAR LINFS20Z1, Z-Wave 20-Ampere.
Not sure if that feature was needed. Guess I need to find something that matches the original...
Robert_fay
Jun 15, 2017
124
Jun 15, 2017
124
Digi-Key has part PB115-ND , however it is only rated at 20 Amps and I believe your original part is 30A.
Might be worth a look though,
ThaNerd
Dec 16, 2017
4
Dec 16, 2017
4
I made a mistake, the original is 20a and new is 30a I believe.
New relay is: sla-12vdc-sl-c
Initial relay is: 507h-1ah-f-s
ThaNerd
Dec 16, 2017
4
Dec 16, 2017
4
But the original relay is only 17a so I was looking for something higher since I'm using this with a garburator which seemed to have killed the relay...
Robert_fay
Jun 15, 2017
124
Jun 15, 2017
124
Maybe you could use something like PB1323-ND and just wire it in to the circuit.
with the schematic give you have 2 pins connected. Without having something to drop into the board this maybe an option.
