K
[email protected]
I need to replace a broken relay. The form factor is like
the P&B R-10 style.
The coil voltage of the original is 150 volts DC.
The R10's I can find are 12, 24, or 48 volts.
Is there some way to either adapt a 12 or 24 volt relay,
or maybe some simple circuit to lower the voltage just
in this one area of the circuit? Maybe a pwm chip
on a little circuit board or something???
I have found that P&B make a 115V DC version, but it's
going to be pretty expensive and even that isn't as
high as I need.
Suggestions?
Chris
the P&B R-10 style.
high as I need.
Suggestions?
Chris
