Reed Relays For Radio Front End: Still Used ?
B
Hello,
Am thinking about purchasing a shortwave defined radio receiver from
WinRadio (http://www.winradio.com/home/g33ddc.htm).
Here is copy from part of their spec sheet:
"The receiver's robust front-end is equipped with an
ultra-high-linearity amplifier which results in exceptional
strong-signal performance. This already robust front-end is further
enhanced with a user-selectable preselector that can operate either in a
fully automatic or user-configurable mode. As many as 119 different
filter combinations can be constructed by the user (91 bandpass, 14
low-pass and 14 high-pass). The front-end employs 34 subminiature
electromechanical relays (rather than often used but distortion-prone
semiconductor switches) to ensure high dynamic range."
Was really surprised to see: The front-end employs 34 subminiature
I am retired now, so haven't kept up withese things, or the state of the
art nowadays, but are they still using electromechanical relays for
front ends feeding a 16 bit A to D ?
Haven't semiconductor switches, caught up with reed relays for this
application by now, or do they "still" provide a lower "on" resistance,
etc. ?
Any thoughts would be most appreciated.
