Reduce Voltage to Zero in Part of a Parallel Circuit
Status
Not open for further replies.
rbcarving
Jul 6, 2016
Jul 6, 2016
New to circuit layout (& theory) but have assembled many from schematics...so forgive if this is an overly simplistic question.
In the attached diagram, is it possible to place a regulator/resistor/diode/etc to cut the voltage to ZERO across the green & blue wires ? ....I did leave a large portion of the components out on the "neg" side of the pot, but this shows where I would need the voltage interruption...(complicated in my mind, but has to do with separating power & audio signals on same path).
Thanks Much,
Brad
Bluejets
Oct 5, 2014
6,920
Oct 5, 2014
6,920
Should already be zero. Black wire creates dead short across green and blue.
Harald Kapp
13,719
13,719
Welcome to EP. Brad.
Right, the pot is useless in this setup.
Besides, a typical pot is not suitable for controlling the current through an LED as it is not designed for the current an LED requires.
That doesn't particularly help us understand your circuit :(
Please be more specific. Explain your project, tell us what you want to achieve, not how you want to do it. We may come up with a solution - or not. No guarantee can be given at this level of non-information.
CDRIVE
Hauling 10' pipe on a Trek Shift3
May 8, 2012
4,960
May 8, 2012
4,960
As Harald stated
but you can dim a LED effectively wiring a Pot as a (Rheostat) variable resistor.
Chris
davenn
14,260
14,260
to the OP .... @rbcarving
when you get all the info together and are prepared to post it
start another thread and post ALL the relevant info
This thread is closed
Status
