Maybe you've destroyed some of the LEDs.
These don't already to be addressable LEDs, so I'll ignore that as a possibility.
When you have killed, or nearly killed, a LED then you often find they either don't come on immediately, it require a higher current to turn on, or are unusually dim.
Since semiconductors tends to fail short circuit, failures tend to cascade.
