A
amdx
John said:A resistor reduces the L/R time constant in both directions. You of
course have to run the coil at rated current, which means you have to
increase the power supply voltage to make up for the steady-state loss
in the resistor.
Jim said:Yep, As I previously posted...
http://www.analog-innovations.com/SED/NMOS_RelayDriver.pdf
You can accurately set a maximum flyback voltage.
in the resistor.
John
Jim said:[...]
What's the 150ohms doing there? Shoulda PWM'ed it.
That's the natural coil resistance of the RELAY. This isn't an SMPS.
Algae. Small plants powered by sunlight.
John
I think that you are both MADE OF SHIT. You are both too goddamnedJohn,
I think you found his sensitive spot.
Mike
I'm amazed!
Your fascination with poop - now fish poop - is really weird. Poop is
mentioned, often featured, in almost every thing you post.
That's really sick.
http://www.wvu.edu/~agexten/aquaculture/pondscum.htm
Your talent for being AlwaysWrong is holding up nicely. As is your
affection for the by-products of life.
yeah, what you said!Rich said:And he (or she) doesn't even know what s/he's talking about. First,
"algae" is plural, i.e., algae ARE algae.
And apparently he/she is unaware of the simple fact that "scum" is
what floats to the top, much like the political system. >:->
Cheers!
Rich
I guess that puts it into prospective.Rich said:
Cheers!
Rich
John
And it's sick that your keep feeding this troll.
I have to puzzle over troll feeders and why they waste everyone's
time replying to such obnoxious jerks. Are you lacking a person
with which to pleasantly correspond? Or are you just feeding your
own ego ?
...Jim Thompson
Cheers!
Rich
Note that you contradicted yourself.
Note also that you are an ignorant berk.
Note also that you have no clue as to how inductive circuits behave.
The relay will drop out only when the coil current falls below the
hold-in current. Any suppression method allows the coil current to
gradually decay to zero and must lengthen the drop-out time.
