R
Ross Herbert
On Mon, 05 Jan 2009 18:25:18 +0000, Eeyore
:Ross Herbert wrote:
:> :Ross Herbert wrote:
:> :> Since your PC is mains powered and it may not have the required isolation
:> :> between the mains side and the sound card input you can do your own thing
:> :> using an approved 600:600 transformer with 3kV isolation rating to
interface
:> the
:> :> telephone line to the sound card input.
:> :He DOES NOT need a 600 ohm transformer since the input impedance of the
sound
:> :card is not 600 ohms <sigh> !
:> Since the application is merely detecting signal "voltage" it hardly matters
:> that the secondary impedance of the transformer is 600 ohms and the input
:> impedance of the sound card is more like 10Kohms. The only reason one tries
to
:> match impedances is where one needs to maximise "power transfer" and that
:> doesn't apply in this case.
:Untrue. A non-optimally loaded audio transformer will not have a flat frequency
:response. Nor is it about power transfer.
:Graham
With regard to a POTS line the VF bandwidth is some 300 - 3400Hz - hardly hi-fi
- so optimal flat frequency response is not an issue.
The fact that the secondary impedance of the 600 ohm transformer does not match
the input impedance of the sound card is totally unimportant in this
application.
interface
:> the
sound
to
:Graham
application.
