Jeff Strickland
Why do you even bother reinventing the wheel, or the light bulb? Use a set
of aligator clips and connect the lamps yo have to a car battery, if they
light they will work, if they don't light they won't work.
Any 120V light will not work in a 12V circuit. I recently had a home owner
that installed a standard light bulb in a low-voltage system, and called me
because the light did not come on. Among various breaks in the wires, I
found the offending bulb. It turns out they (whoever "they" is) make a 12V
bulb for RV applications that use a standard base. Since the bulb she had
fit, she put it in.
fit, she put it in.
