G
Guest
Hi all-
I have an RCA 35" direct view TV. It wont come out of standby.
When the power button is pressed a ticking sound is heard - only while the button is pressed.
Upon inspection, R4001 (1.8 15W) resistor was found to have
cracked solder joints. RT 4201 was replaced because it came apart.
CR4120 was replaced because it was physically blown.
CR4118 was replaced, along with C4102 (2.2@100V)
and C4108 (replaced with 47uf@100V) in an attempt tp fix this problem.
Standby voltage is 143V at TP 4101, and +15 standby is 12.7V at TP4103.
When power button is pressed, both voltages drop (143 down to 110, 127. drops to 10V).
Problem remains - wont come out of standby, ticking sound when power button is pressed.
Appreciate any help
Mark
Appreciate any help
Mark
