Hellmut1956
- Aug 11, 2014
- 69
- Joined
- Aug 11, 2014
- Messages
- 69
Hi friends, I have been looking around to purchase a Zero and none of my sources have those in stock! Can you help me why apparently the Zero is not available?
I have a bit crazy purpose to study the Zero. I am building a Panel for my electronic lab:
Its purpose is to put all the tensions I have availble from my modified PC power supply next to the surface of my lab desk and be able to control by a switch for ON/OFF which tensions I want to have active and which not. Next to each switch I will place a RGB LED, 4 pin with anode, next to it and have it light up in the color I have associated with each individual switch. Now the reason I am considering buying a Zero is that this way I could implement a remote control of this panel from the screens of my PC i. e. by having the Zero access accessible through my internal net via WiFi. I would use one mega8 per 2 tensions/switch/LED controlled by the zero via I2C and so even be able to control remotely the color of the individual LEDs. At the same time those mega8 could also sense the actual tension value and the current and have those read out by the Zero.
If the zero is a nogo I would use my raspi B+
