Radio shack Kit Question on transformer
Discussion in 'Misc Electronics' started by Ken, Dec 30, 2005.
  1. Ken
    Ken Guest
    Hello,
    I have a kit that I bougfht from RAdio Shack , Here is a link of what I am
    talking about. (
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=6019532542&indexURL=
    I would just like to know what are on the transformers in this kit , There
    are no part numbers and I need to replace that part.. The only information I
    have is what is written on the board:
    Output Transformer
    900 8
    Three legs going in and two out with these numbers on top.
    Thank you for your help
    Ken O
    Ken, Dec 30, 2005
    #1
    1. Advertisements
  2. Ken
    Don Bowey Guest
    On 12/30/05 12:03 AM, in article
    K5btf.6401$, "Ken" <>
    wrote:
    > Hello,
    > talking about. (
    > Output Transformer
    > 900 8
    > Ken O
    It is an audio output transformer, 900 Ohms to 8 Ohms, to connect to an 8
    Ohm speaker. The 900 Ohm side may be center tapped.
    Don
    Don Bowey, Dec 30, 2005
    #2
    1. Advertisements
  3. Ken
    DaveM Guest
    "Ken" <> wrote in message
    news:K5btf.6401$...
    > Hello,
    > talking about. (
    > I have is what is written on the board:
    > Output Transformer
    > 900 8
    > Ken O
    It's just a plain old audio output transformer. You already have the most
    important specs: 900 ohms primary impedance with a center tap, 8 ohms
    secondary impedance. Since this is a learning kit, I'm assuming that it is
    low power, maybe a few hundred milliwatts.
    I suggest one such as this from www.mouser.com as a close replacement:
    Catalog # 42TU008
    Primary 800 ohms CT
    Secondary 8 CT
    400 mw
    $ 2.19 each
    It's not an exact match, but, since it's an experimenter's kit, it's
    insignificant. It will still work in the kit.
    Dave M
    MasonDG44 at comcast dot net (Just substitute the appropriate characters in
    the address)
    Never take a laxative and a sleeping pill at the same time!!
    DaveM, Dec 30, 2005
    #3
  4. Ken
    UFO Joe Guest
    I've got tons of those kits, going back 30 years.
    I'm an amateur, but if I can help you...
    Radio Shack used to sell them separately.
    (We lost our Radio Shacks here in Canada - the Colonies - they were bought
    out by some oversized American Crap company - Circuit City - now they're
    into going for the big bucks
    with Big Screen TVs and such, anyhow, forgive me, I digress.)
    Radio Shack used to sell them as "Miniature Audio Transformers" if that is
    any help.
    The numbers on the board are the resistance, 900 Ohms in and 8 Ohms out
    (Most speakers are 4-9 Ohms)
    I really hope this helps you to find a suitable replacement.
    news:K5btf.6401$...
    > Hello,
    > talking about. (
    I
    > Output Transformer
    > 900 8
    UFO Joe, Dec 31, 2005
    #4
  5. Ken
    Ken Guest
    > if that's one of those "30 in one" "learn electronics" type kits
    > any audio transformer that's a "ballpark" match should work.
    > For example Jaycar cat# MM-2532 "1000 ohms CT to 8 ohms"
    > (www.jaycar.com.au)
    > I expect there's a supplier nearer you with a similar product.
    Well you are right, Radio shack 200 in 1 kit.
    supplied by a max of 9volts
    Ken
    And that you for all the help.
    Ken, Dec 31, 2005
    #5
  6. Ken
    Ken Guest
    Because I do not have all the working parts. I decided to simulate this
    circuit in pspice. I wanted to add this part the circuit. ( I only worked
    with very simple circuit using a simulator,..capacitor resistor) there are
    many to chosse from also , I wanted to add a transistor A733, there is none
    in the simulator, how do I go about chooosing out of the 100 shown in the
    simulator ??
    thank you
    Ken
    Ken, Dec 31, 2005
    #6
  7. Ken
    Jim Thompson Guest
    >simulator ??
    >thank you
    >Ken
    Get/Place Part Q2SA733
    ...Jim Thompson
    | James E.Thompson, P.E. | mens |
    | Analog Innovations, Inc. | et |
    | Analog/Mixed-Signal ASIC's and Discrete Systems | manus |
    | Phoenix, Arizona Voice:(480)460-2350 | |
    | E-mail Address at Website Fax:(480)460-2142 | Brass Rat |
    | http://www.analog-innovations.com | 1962 |
    "Winners never quit, quitters never win", Jack Bradley Budnik ~1956
    Jim Thompson, Dec 31, 2005
    #7
  8. Ken
    safemale Guest
    rat shack used to have them
    i think
    ham friend used them in the mic line of his home made rig blaster
    sound card radio interface
    safemale
    On Fri, 30 Dec 2005 09:18:42 -0800, Don Bowey <>
    >wrote:
    >> Hello,
    >> talking about. (
    >> Output Transformer
    >> 900 8
    >> Ken O
    >Don
    safemale, Mar 20, 2006
    #8
  9. Ken
    Guest
    On Friday, December 30, 2005 3:03:30 AM UTC-5, Ken wrote:
    > Hello,
    > talking about. (
    > Output Transformer
    > 900 8
    > Ken O
    (old thread, but appropriately related, I think...)
    A number of the radio shack science fair kits (at least 150-1, 160-1, 200-1) and some other equivalents (at least of the 200-1) have a (second) transformer with the labels 4K on one leg of a center-tapped side and 2K on the other (not center-tapped) side. It also has the label "input transformer".
    Suggestions for a (hopefully inexpensive) reasonable match/replacement for this part, that is readily purchased somewhere greatly appreciated?
    Thanks.
    , Sep 3, 2013
    #9
    >> Hello,
    >> talking about. (
    >> Output Transformer
    >> 900 8
    >> Ken O
    > Thanks.
    Don't be a google-idiot.
    If you have to ask a quesiton, then post away. Dont' tack it onto an old
    thread, especially not when the problem is that google hasn't fixed the
    interface to not allow postings to threads older than 30 days. The rest
    of us don't see the thread on some webpage, the old messages are long in
    the past.
    YOu haven't added anything to the old thread, and the old thread didn't
    need any addtions. You cant' justify why you replied to that old post,
    you just think it's appropriate.
    I thought this was a web type habit, that it was acceptable in the web
    forum world. Yet I saw a message on one of the so many web forums that
    people have moved to instead of good old usenet, and it was about how
    there's no need to resurrect an old thread.
    Michael
    Michael Black, Sep 9, 2013
    #10
    1. Advertisements
Similar Threads
  1. Ken
    Ken, Dec 30, 2005, in forum: Electronic Basics
    11
    2,830
    safemale
    Mar 20, 2006
  2. Lars Torben Wilson
    Radio Shack 160-in-one kit transformer L?
    Lars Torben Wilson, Oct 25, 2005, in forum: Electronic Components
    572
    Lars Torben Wilson
    Oct 25, 2005
  3. Ken
    Ken, Dec 30, 2005, in forum: Electronic Components
    13
    1,611
    safemale
    Mar 20, 2006
  4. MaxVT
    3
    1,172
    Franc Zabkar
    Oct 2, 2007
  5. Norm Dresner
    Ancient Radio Shack "Frequency Standard" kit
    Norm Dresner, Aug 4, 2004, in forum: Misc Electronics
    620
    Charles Schuler
    Aug 4, 2004
  6. Henry
    Radio Shack Stamp Microcontroller Kit
    Henry, Feb 12, 2006, in forum: Beginner Electronics
    1,338
    Henry
    Feb 12, 2006
  7. hbyist
    radio shack science fair input transformer 4Kct 2K
    hbyist, Sep 2, 2013, in forum: Datasheets, Schematics, Manuals and Parts
    864
    (*steve*)
    Sep 2, 2013
  8. Replies:
    1,589
    Mark Zenier
    Sep 11, 2013
Loading...
