Quint Power Supply short
Discussion in 'Power Electronics' started by ParraMeister, Sep 13, 2018.
  1. ParraMeister
    ParraMeister
    Sep 13, 2018
    Hello guys,
    I am new to this site but i heard this is the place to get help.
    So, the problem is that I have a Quint Power supply DC 24 V 5 A, which has shorted out.
    I found the short between he L1 and L2 port.
    I am not extremely knowledgeable on power supplies but I just want to know if it possible to fix this problem and how?
    If this is possible that would be awesome for a new one is quite expensive.
    Any advice?...
    #1
    1. Advertisements
  2. ParraMeister
    kellys_eye
    Jun 25, 2010
    3,812
    1,023
    West Coast, Scotland
    Welcome to the forum.
    Take it apart! You have a short on the mains input side which usually means the main switching component (a transistor or a MOSFET) has gone short. You may also have a short in the main bridge rectifier. We really can't tell from a picture of the box!
    We may also require you to take some test measurements. Do you have a test meter and can you use it? If not, suggest you get one and learn!
    kellys_eye, Sep 13, 2018
    #2
    1. Advertisements
  3. ParraMeister
    ParraMeister
    Sep 13, 2018
    Okay so I took it apart and found that one component is busted, I am not sure what it is ..a transistor of sort maybe?
    anyway, replacing it is not a problem, but I want to try and figure out what could cause it to get fried.
    I think it must be because of a power surge I had recently.
    Yes I can work a multimeter and I do have one at my disposal, no problem.
    #3
  4. ParraMeister
    Ylli
    Jun 19, 2018
    53
    13
    Ylli, Sep 13, 2018
    #4
  5. ParraMeister
    kellys_eye
    Jun 25, 2010
    3,812
    1,023
    A wider view of the board would help too.
    #5
    1. Advertisements
