M
M. Hamill
I'm an engineer albeit not an E.E., and I have a few questions that some of
you might be able to answer:
- What is the typical efficiency of the power distribution system as it
applies to typical residential customers with 120/240 VAC? (I ask this
because it seems to me that it must be substantially below 100%, when one
considers that there are 5 or more transformers between the power's company
generation station, and end users; plus impedance losses, etc.) Or,
rephrased, for every 100 kilowatt-hours used at a home, how many
kilowatt-hours would be required at the generating plant's high-voltage
connection to the distribution system?
- What is the approximate efficiency of the best DC motors available these
days (power available to motor divided by mechanical equivalent of
electrical energy used?) Also, what is a more typical efficiency for DC
motors?
- Can DC motors be run more efficiently if there are designed to run at
higher voltages (compared to lower voltage DC motors?)
Thanks in advance,
M.H.
motors?
Thanks in advance,
M.H.
