Prithwiraj Bose
- May 11, 2017
- 5
- Joined
- May 11, 2017
- Messages
- 5
I am new to Electronics and have been spending time for a while now as a hobbyist. I have a fairly simple question regarding the circuit below:
I have made the circuit but the it would only regulate between 18V-24V and sometimes the range slightly changes based on the POT used. But still, I do not get the full range starting from or very close to 0V upto 25V. What should be the voltage around R1 ideally? I am expecting to regulate the voltage without compensating the current limit using this LM317 based circuit. But somehow when the power transistor is connected the LM317 stops behaving as expected. When it is detached, I see expected range of voltage. Isn't the principle correct that Ve should be Vb - 0.7v approx and thus this circuit should output a regulated voltage across R1?
I have been trying to figure out the problem and tried to get help from other forums. I have only received the average answers saying why linear regulators are bad, that I should use an SMPS and all other suggestions which doesn't answer my question. I am trying to learn it and this circuit has drawbacks, which I admit while asking this question. I am expecting to get some meaningful answer here which explains why the circuit doesn't behave as expected, which my newbie understanding can grasp. Please help.
