A
[email protected]
I have a few questions on ic timers. I'm looking for a timer to
trigger a relay to run an 80mm fan for 1 minute every 2 hours or
somewhere around there. I would also like to have the circuit trigger
a led light setup for 4 or 5 hours every day.
First off I'm wondering if this is possible with a 556 timer, and if
so I have no clue on the parts I need. I've done a bunch of searching
and can't find the info I'm looking. If anyone knows of some sites I
could look at to read up how this can be accomplished it would be very
much appreciated.
Also does anyone know how long a circuit like this will run accurately
on a single battery charge, it doesn't need to be exact to the second,
just switch the relays on and off reasonably close to on time.
If i remember correctly from my intro to engineering class we
programed a simple robot to run an obstacle and as the batteries were
used up the timing was slowed.
If you haven't guessed already I'm new to circuits, but I'm pretty
sure with a little bit of guidance I can figure this out.
Thank You in advance for any advice on my project.
Westby
much appreciated.
Westby
