Question about Diode potential of anode with respect to cathode
Discussion in 'General Electronics Discussion' started by skyline1397, Sep 13, 2017.
  1. skyline1397
    skyline1397
    Sep 13, 2017
    If I have an ideal diode and I apply -9 V in the anode (P-type junction) and -10 V at the cathode (P-type junction) would the diode become forward biased??
    I get that the current-voltage relationship of an ideal diode shows that as long as the voltage across the ideal diode is non-negative i.e. V≥0, the ideal diode looks like a short circuit but the graphs refer to V. Is this V equal to V(anode)-V(cathode)?
    Where V potential of anode with respect to cathode
    #1
    1. Advertisements
  2. skyline1397
    8,287
    1,560
    Germany-Europe-Earth-Sol System-Milky Way-Laniakea
    Voltage is always about potential differences. What is the potential difference V(anode)-V(cathode)?
    A positive voltage between anode and cathode will make the diode conducting.
    A zero or negative voltage between anode and cathode will make the diode non-conducting.
    Harald Kapp, Sep 13, 2017
    #2
    1. Advertisements
  3. skyline1397
    dorke
    Jun 20, 2015
    2,344
    662
    Welcome to EP.
    You can not apply +1V "on" an ideal diode.
    The most possible is 0V,
    this will case the diode to conduct ,
    the current will be limited by the external resistance.
    dorke, Sep 13, 2017
    #3
    BobK likes this.
  4. skyline1397
    Ratch
    Mar 10, 2013
    959
    283
    You have to have an infinitesimal amount of voltage across an ideal diode for current to be present. Even a copper wire short will not have any current existing at zero volts.
    Ratch
    Ratch, Sep 14, 2017
    #4
  5. skyline1397
    7,114
    1,480
    Worcester, MA
    Which is why ideal diodes do not exist.
    BobK, Sep 14, 2017
    #5
  6. skyline1397
    8,287
    1,560
    I like to think that the original question was not so much about the behavior of an ideal diode as about the quadrant of the characteristic where this diode would be operating under the given conditions.
    Of course an ideal diode doesn't exist and current would be infinite - unless limited by e.g. the limited capabilities of the power sources used.
    Harald Kapp, Sep 14, 2017
    #6
    1. Advertisements
