Query as to the existence of a component
LeadStuffer
Feb 15, 2017
3
Feb 15, 2017
3
Hello.
I'm not great with the hardware side of electronics, and so am not sure as to whether a specific type of component exists or not.
The type of component I'm after is similar to a transistor, in that it would use a base to control a current, however a transistor (as I understand it) is just an on/off switch controlled by the base.
I was wondering if there is a similar component that controls the current through the collector and emitter, so that this current is proportional to the power given to the base.
Does anyone know of such a component, or would I just have to make a new circuit to do something like this?
davenn
14,260
14,260
hi ya
welcome to EP
your understanding isn't correct :)
if the transistor is fully turned on or off then it acts like a switch ......
if the voltage / current to the base is varied, then the collector - emitter current is also varied .... hey presto ... an amplifier
LeadStuffer
Feb 15, 2017
3
Feb 15, 2017
3
Further question; would the voltage(input.base) be proportional to the voltage(output) and the current(input.base) be proportional to the current(output), or would it just go on power (P=VI) and the rest be determined by the resistance of the circuit (V=IR)?
I don't know the components, but i do know the physics
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
Google "transconductance"
