C
Chris
I have a few op amps driving a ph probe inital value .059mv/unit boosted
to 4 and offset by 2 volts ... anyhow the valies i read are correct, but
once i plug the serial from my pc to a db9 / max232 std config the
readings go off totally, the max232 is using 10uf/50v from power and to
ground taking pins 2/3 from db9 grounding shield and 5 to common, 7+8
jumped 4+6 jumped
Anyone have any ideas? it runs perfectly fine when the serial is
unplugged...
jumped 4+6 jumped
unplugged...
