Problem 3: Alphabetical Substrings
Assume s is a string of lower case characters.
Write a program that prints the longest substring of s in which the letters occur in alphabetical order. For example, if s = 'azcbobobegghakl', then your program should print
Longest substring in alphabetical order is: beggh
In the case of ties, print the first substring. For example, if s = 'abcbcd', then your program should print
Longest substring in alphabetical order is: abc
For problems such as these, do not include raw_input statements or define the variable s in any way. Our automating testing will provide a value of s for you - so the code you submit in the following box should assume s is already defined. If you are confused by this instruction, please review L4 Problems 10 and 11 before you begin this problem set.
Note: This problem is fairly challenging. We encourage you to work smart. If you've spent more than a few hours on this problem, we suggest that you move on to a different part of the course. If you have time, come back to this problem after you've had a break and cleared your head.
CORRECT
s = 'otaigtxslrmxhiuloiovxuhm'
Output:
Longest substring in alphabetical order is: iovx
I like the last line about take a break and clear your head LOL I am having difficulty with these more abstracted arguments: for i in range (1, len(s)) - several functions are combined and I seem to lose my place.
Can someone explain line by line what is going on?
I also don't see where the computation is occurring to check for alphabetical order.
Thank you in advance.
Code:
curString = s[0] #I see curString and longest variable being set to zero initially.
longest = s[0]
for i in range(1, len(s)): #Contents of variable i while in range starting at 1 and ending at the length of variable 's'
if s[i] >= curString[-1]: #Loop if variable s[i]? is greater than curstring variable[-1]
curString += s[i]
if len(curString) > len(longest):
longest = curString
else:
curString = s[i]
print 'Longest substring in alphabetical order is:', longest
CORRECT
Output:
