Puzzling problem with sensor and flickering lights
Discussion in 'LEDs and Optoelectronics' started by Gregory, Jan 15, 2018.
  1. Gregory
    Gregory
    Jan 15, 2018
    I'm hoping someone can help me figure out a puzzling problem with a light switch and overhead light. I have only basic handy homeowner knowledge of electrical issues, meaning I can install switches and fixtures but I don't know much when it comes to troubleshooting. Sorry for the long setup here, but I'm trying to give you an accurate picture.
    In an entryway from the garage, I have an overhead light fixture that I'd like connected to a motion sensor switch. I had that setup for years but it never worked quite right. The lights would flicker and sometimes would stay on at a low level when the motion sensor was not activated. It also seemed that light bulbs burned out quickly in this fixture, so I ended up using various types of bulbs in the fixture as I replaced them. I could not see any improvement in the issues, though I've learned through some reading that the low level constant on may be related to LED bulbs.
    More recently I decided I wanted to fix this problem once and for all. I thought maybe the motion sensor switch was bad, so I replaced it with a new one. The problem persisted. So I thought maybe the problem was with the light fixture. I removed the old one and saw that the visible wires connecting to the light bulb sockets were severely degraded, with the wiring exposed in a couple places. (This fixture had been in place about 12 years.) As I prodded the wiring, it was so brittle that it just fell away and exposed large sections of the wiring. I found this very concerning as a fire hazard, of course, so I was glad to be replacing the fixture.
    I installed a new fixture (fixture B), and I now had a new motion sensor (sensor 2). So both new components. The flickering continued, and the motion sensor only worked intermittently. Sometimes I'd walk by and hear the click of the motion sensor activating, but the light would not come on. Sometimes it would come on a minute or two later. Other times it would seem to work properly.
    A more knowledgeable friend suggested that maybe the bad wiring in the original light fixture was the culprit and since fixture A was still in place when I installed sensor 2, maybe fixture A had somehow damaged sensor 2. So now sensor 2 was the problem, we suspected.
    To test that, I removed sensor 2 and replaced it with a simple toggle light switch. The switch turned the light on and off properly, but there still was flickering when fixture B was on.
    At that point I had become very uneasy with the idea of some sort of wiring issue that could be dangerous, so I just removed the toggle light switch, capped the wire ends, and closed up the wall plate.
    I welcome any thoughts or suggestions.
    #1
    1. Advertisements
  2. Gregory
    kellys_eye
    Jun 25, 2010
    3,122
    829
    West Coast, Scotland
    How old is the wiring? Is it up to code? Check for a junction box somewhere in the feed line.
    Loose fixing screws can result in excess heat at the joint which can dry out insulation and make it brittle.
    Check also for rodent damage.
    kellys_eye, Jan 15, 2018
    #2
    1. Advertisements
  3. Gregory
    Gregory
    Jan 15, 2018
    The house is about 25 years old and everything is up to code as far as I know.
    #3
  4. Gregory
    Tha fios agaibh
    Aug 11, 2014
    1,507
    487
    I suspect you might be using the wrong type sensor. Some don't play nice with led lamps. Some sensors are designed not to activate during daylight conditions (..and will flicker when light from overhead fixture reaches it). Make sure you use a sensor designed for your specific application.
    I would reinstall the toggle switch and temporarily put a high wattage lamp in the fixture and see if the circuit still works properly.
    If you have any bad connections the heavy load will likely make the lamp turn off. If you can turn it on and off without any flickering, you know the problem is with the sensor.
    Tha fios agaibh, Jan 15, 2018
    #4
  5. Gregory
    duke37
    Jan 9, 2011
    4,932
    643
    Derbyshire. UK
    I agree with this. My sister had flickering lights in the hall, I tracked the wires with a little transmitter and a portable radio eventually finding a junction with poor connections which had been close to fire. The house is about 30 years old and was wired by an ignorant yob. He did not think that earth wires needed to be connected. The firm went bankrupt
    There is likely to be rodent damage in farm machinery such as combine harvesters, often only showing a fault when the machine is juggling up and down.
    duke37, Jan 15, 2018
    #5
    1. Advertisements
