Hi there,
A project I'm working on is the effect of resistance, inductance and capacitance on a single phase system. A 230Vrms supply is connected in series with a user-defined resistors, inductor and capacitor.
In the brief, we have been told that when simulating this circuit when looking at the effect of a pure resistor we must set inductance to 0H but the capacitance must be set to a value such as 1F. I understand this, as this capacitor creates a virtual short circuit across it and we cannot use a 0F capacitor as this would essentially be a break in the circuit. I also understand why the inductor can be set to 0H.
What I do not understand is the guidance given when investigating the effect of a pure capacitor circuit - inductance is again to be 0H but the resistance should be set to 1 Ohm? I would have expected to use 0 Ohms.
My initial thoughts are that this relates to the time constant equation, t=RC - hence if R was 0 then there would be no time constant and therefore the circuit would not function properly. Is this correct?
Many thanks,
Kyran Hill
Many thanks,
Kyran Hill
