- Joined
- Nov 17, 2011
- Messages
- 13,722
The max. Threshold voltage is Vgsmax = -4 V. The 555 operated from 12 V can easily generate a lower gate-source voltage (note that Vgs is negative since source is connected to 12 V). The MOSFET should be turned on hard.Just what this figure actually is depends on how hard the mosfets are turned on.
At Rds = 0.018 Ω the observed voltage drop is equivalent to a current of Ids = 166 A -> unlikely. The voltage drop is most certainly due to other effects.
- What is the gate-source voltage at the mosfet when on?
- What is the drain current of the mosfet when on?
- Is the mosfet properly heatsinked? (at 30 A it will dissipate 16 W! See the note at the bottom of the schematic in post #19)
