I am using a pair of PT4115E Drivers (Data Sheet: https://people.xiph.org/~xiphmont/thinkpad/PT4115E.pdf ) to drive two different arrays of LEDs.... The circuit is identical to the "Typical Application Circuit" with the addition of a 10uF Capacitor across the LED arrays ( to reduce ripple, as shown on page 13 of datasheet ) and the rectifier diodes for AC operation are omitted as this is a battery operated device.
One array is 12 * 1W Red Leds configured as 4 parallel sets of 3 LEDs in series with a nominal Vf of 5-6V and a max current of ~2A.
The other array is 12 * 0.5W Green LEDs configured as 6 parallel sets of 2 LEDs in series with a nominal Vf of 5-6V and a max current of ~ 1A.
Aside from the two PT4115Es the circuit also has an LM1117 5V Regulator and an ATTINY2313a. The ATTINY2313a is used to provide PWM to both arrays to produce a "Fade-In" effect.
All discussion in this thread deals with power consumption after the "Fade-In" Period has ended and the PT4115E is in "Free Running Mode" ... that is current is regulated solely by the feedback resistor and NOT by PWM.
The target total power consumption for the Red LEDs is ~5W.
The target total power consumption for the Green LEDs is ~2.5W.
I have not attempted to directly measure the current in the LED arrays while powering them with the PT4115Es; however, using a bench supply with adjustable CC/CV outputs I have measured the Current of the LEDs at various Forward Voltages. I feel fairly confident measuring the forward of the LED arrays while powered by the PT4115E yields a good indication of the actual average current flowing through them ....
Finally, my problem // question ... Testing the PT4115Es with their respective arrays, the power consumption of the circuit varies considerably as the Supply Voltage increases.
The RED Array circuit consumes 3.8W ( 8.0V @ 475mA ) .... and the LEDs have a forward voltage of 6.28V ....
Stepping up the supply voltage in 1 volt increments increases the Current & consequentially the Power consumption:
Consuming 6.63W ( 13.0V @ 510mA) ..... and a forward voltage of 6.36V.
So, The input power changes as follows:
0.475A * 8.0V = 3.8W
0.510A * 13.0V = 6.63W
1 - (3.8W / 6.63W) = 42.7% increase in input power
The Power consumed by the LEDs changes as follows:
A forward voltage in the RED array of 6.28V corresponds to a 495mA forward current.... ==> 0.495 * 6.28 = 3.1086
A forward voltage in the RED array of 6.36V corresponds to a 555mA forward current.... ==> 0.555 * 6.36 = 3.5298
1 - (3.1086 / 3.5298) = 11.93% increase in power consumption
Efficiencies Compared Directly:
3.1086W / 3.8W = 81.8% Efficiency
3.5298W / 6.63W = 53.2% Efficiency
I have tested the circuit with a 10uH inductor, a 22uH inductor, a 33uH inductor and a 100uH inductor and the numbers are virtually the same.... Additionally while the Forward Voltages and Currents are different in the Green Array, the efficiency statistics are virtually the same.
In the original version of this circuit the PT4115E drivers were set @ 900mA and PWM was employed to limit the "final current" to 500mA in the Red array and 250mA in the Green array ... I don't have one of the old units to test, but I am 99.99% certain that I remember the efficiency increasing as the supply voltage increased ... I also remember the efficiency being in the 90% + range ....
Before I build a prototype with the current set higher and alter the firmware to control the "Final Value" .... can anyone think of a good reason my efficiencies would be so messed up?
Thanks!
Fish
Thanks!
Fish
