P
panfilero
I have a couple issues I'm having trouble with, I'm using orcad 16 and
trying to simulate a simple circuit, it's basically two pulse
generators VPULSE each going through a diode... I'm trying to "diode-
or" two voltage sources... but I keep getting these large voltage
spikes.... say if I set the pulses at 12V I get these 16V spikes...
and then they settle to 12V here is my circuit, where V1 and V2 are 12
Volt pulses slightly offset from one another... I was especting to
seee 12 V on the Vout regardless of whether V1, V2 or both were on
V1 O-----|>|-------
D1 |
|-------------O Vout
V2 O-----|>|-------
D2
My other issue is, I try to set my pulses for 1 second each and then
want my simulation to go to 3 seconds, but it takes forever to run
through the simulation, does anyone know how I can speed that up....
can I change the sampling rate or something so it would fnish faster?
Much thanks
J.
V1 O-----|>|-------
D1 |
|-------------O Vout
V2 O-----|>|-------
D2
Much thanks
J.
