Hello everyone reading this post! First of all, I don't understand a whole lot of electronics... In fact, I just started out... I'm a student and I stumbled upon this project called "the slayer exciter" and I'd like to make it work for the science fair at my school.
As you may have guessed it didn't work that well and that's why I'm here, hopefully I'll get this fixed before the delivery...
This is the circuit:
For the seconday coil, I used a PVC pipe with about 2.5 cm of diameter(1 inch) and 9 cm of height(3.54 inches) and winded the coil all the way down, for the Primary coil I wound up 4 turns in the opposite direction of my secondary coil.. I used a 2N2222A transistor and I think I connected the ports correctly ( My transistor gets really hot within a few seconds of the circuit being turned on ) I used a 22k resistor.
I have some questions regarding electronics as well.
1. Can I use common copper wire to connect my circuit? ( my cables had a bunch of little wires instead of a solid grey wire. )
2. And shouldn't this circuit be wrong as it's open?
Thanks in regards, André
